The IEEE 802.1ag application failed to open a communication channel with the system to communicate with the outside world.
When this happens not packets can be send out, or received from the network. See if restarting the process solves this problem. Under normal circumstances this should not happen, however if it does, please escalate to engineering.
Error
Failed to allocate global dot1ag packet socket, error: %errormsg%.
| Name | Type |
| errormsg | String |
